Users may notice that the Quarantine portal default view displays the Envelope Sender (routing address) rather than the Body Sender (the actual "From" address seen in email clients).
Email Security.cloud
The default view in the portal may be set to prioritize the RFC5321 Envelope Sender for routing transparency. However, users frequently require the RFC5322 Body Sender to identify the actual sender of the message without opening the email.
To display the actual sender details in the Quarantine portal list view, follow these steps to add the Body Sender column:
The Quarantine portal will now display the actual sender details in the newly added column.
