Understanding Envelope Sender vs. Body Sender
Article ID: 435355
Email Security.cloud Policy-Based Email Encryption PGP Cloud Email Threat Detection and Response
Users may notice that the sender information displayed in the "Envelope Sender" column of the Email Security.cloud interface does not match the actual sender shown when an email is opened.
The Envelope Sender may display as "Bounce" or shows a long, unique address that is not the intended sender's email address.
This behavior is due to the fundamental technical difference between how emails are routed and how they are displayed to the end user.
TermAlso Known AsDefinitionStandard
Envelope SenderEnvelope From, MAIL FROMThe address used for SMTP routing. It is the address used by mail servers to handle delivery and return bounce messages.RFC 5321
Body FromBody Sender, Header From,
Friendly From
The address that appears in the email client (e.g., Outlook, Gmail). This is what the end user sees in the "From:" field and recognize as the sender.RFC 5322
The interface columns are labeled to reflect which sender type is being displayed.
  1. Verify Sender Information: If the Envelope Sender shows "Bounce" or a different address, it is functioning as intended for SMTP routing. This is common with bulk email services or distribution lists.
  2. Identify the True Sender: To view the "Body Sender" or display address, the user must click into the email record to see the message headers and full body details.
  3. Track and Trace: When performing searches in Track and Trace, the administrator can search using the Envelope Sender if the specific routing path is known, or filter by recipient and subject to find the corresponding record for a specific Body Sender.
Note that Email Impersonation Control and certain whitelists (like Approved Senders) are evaluated against the Envelope Sender at the time of the scan.
