How to monitor network traffic volume for egress interfaces in VMC on AWS using VCF Operations for Networks
Article ID: 435112
Customers using VMware Cloud (VMC) on AWS may need to monitor network traffic volume (e.g., total bytes or 'Top Talkers') flowing through egress interfaces, such as:
  • Public Internet Egress
  • AWS Direct Connect (DX)
  • VMware Managed Transit Gateway (vTGW) / Transit Connect
  • VMware Cloud on AWS (VMC)
  • VCF Operations for Networks
  • VMware NSX
By default, standard VMC inventory views provide high-level interface metrics, but deep-dive flow analysis, "Top Talker" identification, and granular traffic volume reporting for specific egress paths (like vTGW) require the configuration of IPFIX and an external analytics tool like VCF Operations for Networks.
VMware VCF Operations for Networks is the recommended tool for deep visibility into VMC on AWS network traffic. By correlating IPFIX data from the SDDC Tier-0 router with AWS API data, VCF Operations for Networks provides comprehensive metrics for flows traversing all egress points.
Prerequisites
  • VCF Operations for Networks Version: Ensure you are using a supported version (e.g., 6.14.2 or later).
  • Collector Placement: The VCF Operations for Networks Collector OVA must be deployed on a Native VMC Segment within the SDDC (not an L2VPN extended segment) to ensure low-latency communication with ESXi hosts.
  • Firewall Rules: Configure the Management Gateway (MGW) Firewall to allow:
    • UDP 2055: From SDDC hosts to the VCF Operations for Networks Collector.
    • HTTPS (443): From the Collector to the NSX Manager and vCenter.
Configuration Steps
1. Define the IPFIX Collector in NSX Manager
  1. Log in to the NSX Manager UI.
  2. Navigate to Plan & Troubleshoot > IPFIX.
  3. Add a new Collector by providing the IP address of your VCF Operations for Networks Collector VM.
  4. Set the UDP port to 2055.
2. Create and Apply a Switch IPFIX Profile
  1. In the same IPFIX tab, create a Switch IPFIX Profile.
  2. Apply this profile to specific segments or the Tier-0 Uplink to monitor egress traffic.
  3. For an optimal balance of accuracy and performance, use the following settings:
    • Active/Idle Timeout: 60 seconds.
    • Packet Sample Probability: 10% (0.1).
  4. Click Set under "Applied To" to select the targets for monitoring.
3. Verify Data in VCF Operations for Networks
Once the flows are reaching the collector, use the following query in VCF Operations for Networks to visualize egress volume: sum(bytes) of flows where flow type = 'Internet' group by source vm
Related Documentation: Configure IPFIX in VMware Cloud on AWS (Broadcom TechDocs)
