/vmfs/volumes/<datastore>/<vmdirectory>/vmware.log of the VM with vGPU attached :YYYY-MM-DDThh:mm:ss.xxxZ In(0x)+ vmx - Power on failure messages: Could not initialize plugin 'libnvidia-vgx.so' for vGPU 'nvidia_a16-1b'.
YYYY-MM-DDThh:mm:ss.xxxZ In(0x)+ vmx - Module 'PCIPluginLate' power on failed.
YYYY-MM-DDThh:mm:ss.xxxZ In(0x)+ vmx - Failed to start the virtual machine.Specific NVIDIA GPUs, such as the A16 or A2, require SR-IOV (Single Root I/O Virtualization) to be enabled at both the BIOS/UEFI level and within the ESXi host settings to function as a vGPU. If SR-IOV is disabled for the relevant PCI device on the ESXi host, the vGPU plugin will fail to initialize.
Enable SR-IOV for the relevant PCI device on the target ESXi host via the vSphere Client and then restart the ESXi host.
