Tunnels between NSX Edge and ESXi Transport nodes showing as Down
Article ID: 433411
VMware NSX VMware vSphere ESXi
  • Tunnels between NSX Edge and ESXi transport nodes displays as Down even when there are no network connectivity issues.
  • When placing packet capture on the ESXi host where the Edge vm resides, the INIT BFD packet will be seen on associated ESXi vmnic however not on the edge switchport.
  • Tracing the packet using below capture point on the ESXi host
    pktcap-uw --uplink <vmnic_number> --scrip <source_ip> --dstip <destination_ip> --trace
    "VXLAN Module Drop" reason will be seen
VMware NSX-T Data Center 3.x
VMware NSX 4.x
This issue occurs because the Edge VM TEP interface is connected to a vDS portgroup on a host switch which is used/prepared by NSX.
Configuration issue on NSX-T Edge TEP networking options
To resolve this issue, create a logical segment on the VDS and assign the Edge VM TEP interface.
For more information, refer  KB 317168 - NSX-T Edge TEP networking options.
Also Refer Tunnels between NSX-T Edge and ESXi nodes displays as Down even when there are no connectivity issues
