How to schedule virtual machine power operations in vSphere
Article ID: 433217
VMware vSphere ESXi VMware vCenter Server
Automating the periodic power on and power off of specific virtual machines in a vSphere environment.
  • VMware vSphere 7.0
  • VMware vSphere 8.0
By performing the following steps, power-on and shutdown tasks can be created that are executed periodically.
  1. Log in to the vSphere Client with administrator privileges.
  2. Select [Inventory] from the menu.
  3. Select the virtual machine on which you want to execute the task.
  4. Select [Configure] from the tabs, and select [Scheduled Tasks] within the settings items.
  5. Select [NEW SCHEDULED TASK], and select the desired action from the drop-down menu.
  6. Enter the task name, description, execution, etc. Select the execution interval according to the repetition interval, and enter settings such as the start time.
  7. Select [SCHEDULE THE TASK] and save the task.
