ESX: 8.0u3
vCenter: 8.0u3
The migration fails because of a networking configuration discrepancy between the source and destination ESXi hosts. Port mirroring sessions and their associated TCP/IP stacks reside at the switch and host levels.
When a VM is moved, particularly between different vCenters. The destination host must have an identical mirror netstack instance and a dedicated virtual adapter (vmknic) already active. Without this matching infrastructure, the vCenter Server cannot hand off the VM's networking requirements to the new host.
To resolve this issue, create the mirror stack configuration across all participating hosts in the cluster.
Identify Source Configuration:
Review host networking settings in the vSphere UI or via the ESXi command-line interface (CLI).esxcli network ip netstack list
Configure Destination Host:
Navigate to the Destination Host > Configure > Networking > TCP/IP configuration.
Ensure the mirror stack is present and active.
Create or verify a VMkernel adapter on the destination host that is specifically assigned to the mirror TCP/IP stack.
Validate Consistency:
Ensure that the MTU settings and VLAN IDs for the mirror virtual adapters match across both hosts.
Retry Migration:
Once the destination host has an active mirror netstack instance and virtual adapter, re-run the vMotion wizard.
If traffic mirroring is no longer required for the virtual machine, an alternative workaround is to disable the port mirroring property on the VM's dvPort before attempting the migration.
Additional Doc - What is Port Mirroring Interoperability
