1. All VMs under certain Network adapter [VLAN_110] are not showing Port Group metric
2. From vSphere UI, navigate to the VM under VLAN_110 and make note of the vm_id from the URL.
For example: https://<vCenterFQDN>/ui/app/vm;nav=h/urn:vmomi:VirtualMachine:vm-17:9f66631a-9771-4298-a85b-xxxxxxxx/summary
3. Open the MOB page of the VM
https://<vCenterFQDN>/mob/?moid=<vm_id>&doPath=config.hardware
4. Navigate device of Type VirtualDevice[For example from above screenshot: device[4000]] > Virtual DeviceBackingInfo > DistributedVirtualSwitchPortConnection > Make note of the portgoupkey [dvportgroup-xxxxx]
5. Verify the dvportgroup-xxxxx, by navigating to the Network Adapter [VLAN_110] in vSphere UI
https://</ui/app/dvportgroup;nav=n/urn:vmomi:DistributedVirtualPortgroup:dvportgroup-365290:9f66631a-9771-4298-a85b-xxxxxxx/summaryvCenterFQDN>
VMware Aria Operations Version: 8.18.5
Due to data inconsistency within vCenter, we are seeing this issue in vROPS.
dvportgroup-xxxx is different when checked from vSphere UI and from the MOB UI
vCenter team needs to be engaged to fix the data inconsistency.
