I currently run Web Viewer 12.1 and it does not have an API. I would like to run Web Viewer 14.0 at the same time so I can use the API. Can they both be run concurrently?
OM Web viewer 12.1, 14.0
Yes, You can run both versions of Web Viewer at the same time. In fact we recommend that you do so in particular if you need an API.
