Work Processes (WPs) are consistently operating at very high utilization levels, frequently between 85–100%, with repeated CPU spikes reaching near-maximum capacity. This sustained saturation results in WPs remaining busy for extended periods, causing overall performance impact.
Release: 24.x
Component: Automation Engine
DE177576
Update to a fix version listed below or a newer version if available.
Fix version:
Component(s): Automation.Engine
Automation.Engine 24.4.2.HF3 - Available
Automation.Engine 24.4.3 - Available
Public Desc: A problem has been fixed that caused performance degradation in the Automation Engine.
