Links to Symantec Workflow Solution help articles, examples, and videos
Article ID: 430235
Client Management Suite IT Management Suite
There is a lot of Workflow Solution information scattered around KB's and Broadcom Community.  This KB will try to bring all of this information together in one KB for reference by Customers.
Videos:
Installation:
Service Request Template Videos (great for getting started with Workflow):
Publishing How-To Videos:
Generator How-To Videos:
Components How-To Videos:
Additional Advanced Concepts:
Process Manager and Reporting Videos:
Process Manager Reporting Using External Data (no valid link available)
Altiris Integration Videos:
Mobile Management Integration Videos:
SEP Integration Videos:
Articles:
Here is a list of links to useful Workflow Documentation.
Another article which lists all the extra Projects you can download which don't come with the Solution but have been created over time to add functionality to the Product:
Workflow Series
    • Tools
      • There are a number of tools that ship with Workflow, see what they are and how they work here.
      • By name, the tools are: Application Editor, BusinessTimeSpan Editor, Composer Theme Editor, Credentials Manager, License Status Manager, LocalMachineInfo Editor, Log Viewer, Messaging Console, Schedule Editor, Screen, Capture Util, Server Extensions Configurator, Task Tray Tool, ToolPreferences Editor, Workflow Explorer
    • Integration
      • Generators
        • ​There are a number of Generators available in the Solution.
          • REST Generator
            • There has always been a Web Services Generator but in 7.6 a REST Generator was added.
    • AngularJS Components
      • AngularJS was added in 8.# release, this brings a more modern aspect to your Workflow Web Forms.
    • Plugins
      • There are a number of Plugins that ship with WF Manager, see what they are and how they work.
    • Plugins - Protirus
      • A number of additional Plugins with added functionality to extend the solution such as:
        • Reset Cache, License Status, Generate Business Model, Create GUID, Encryption Keys Generator, Export Translation Strings Plugin, Component Report, Model Report
    • Plugin - Developer Guide
      • If Workflow doesn't do something you want it to why not extend it with your own Plugin, this Developer Guide shows how.
    • Component - Developer Guide
      • Components make up the backbone of Workflow, learn how to create your own here.
    • ProcessManager - WebPart - Developer Guide
      • PM consists of a number of Web Parts to show various Process data, learn how to build your own Web Parts which this Developer Guide.
    • Examples
      • Workflow comes with a set of Examples to get to grips with how to work with the Designer and allow you to run those common scenarios in your company.
Individual Items
Symantec:
There are a number of Component Libraries that have been built to interact with other Symantec Solutions.
Errors:
How to add custom data to existing processes like Incident Management, Change Management etc
https://www.symantec.com/connect/articles/how-add-custom-data-existing-processes-incident-management-change-management-etc
Explaining the use of certain Components and ideas to add to Workflow Projects.
SMP
Links to other useful Articles...
Here are some references to Component Pages, noting they may be incomplete:
Contributing to Workflow’s Collaborative Component Pages
Workflow Collaborative Documentation Comes to Connect
How To: Contribute or Suggest Changes for Collaborative Articles on Connect (Now Broadcom Community)
