Edge Node shows "UNKNOWN" and "Not available" status
Article ID: 427233
VMware NSX
The "Tunnels" for an edge node shows as "Not available, and the "Node Status" shows as Unknonwn If the details are clicked, it shows all tunnels are up and no error found.
There is no data path impact
VMware NSX
Synchronisation issue with the GUI
Edit the settings of the affected Edge node and save without making any changes
