OData connection in Power BI
Article ID: 425510
Clarity PPM On Premise Clarity PPM SaaS Clarity FedRAMP
I’m unable to change the "User ID & Password" settings on the OData connection in Power BI.
Clear Credentials & Restart:
- Go to File > Options and settings > Data source settings.
- Select Global Permissions, find your data source, and click Clear Permissions.
- Restart Power BI Desktop and try connecting again.
