Reverting ESXi advanced setting using CLI to its default value
Article ID: 425061
VMware vSAN VMware vSphere ESXi
This article outlines the process of resetting advanced settings on ESXi to default values using CLI.
vSphere ESXi, all versions
In order to revert ESXi advanced setting to its default value:
1. Log into ESXi host as root using SSH
2. Run esxcfg-advcfg -d followed by /SectionName/OptionName of choice, example:
esxcfg-advcfg -d /LSOM/diskIoRetryFactor
diskIoRetryFactor reset to default
Value of diskIoRetryFactor is 2
NOTE: Values default for an ESXi build are always recommended, unless directed otherwise by Broadcom on a case per case basis.
If setting is misspelled or not yet introduced in the given release then running 'get' option will return:
esxcfg-advcfg -g /LSOM/thissettingdoesnotexistyet
Exception occurred: Unable to find option thissettingdoesnotexistyet
This operation does not have any effect on the host.
Further information can be found in: Configuring advanced options for ESXi / https://knowledge.broadcom.com/external/article/310338/configuring-advanced-options-for-esxi.html
