Buffer Overrun issues with NSX Edge during large file transfer
Article ID: 423726
VMware NSX VMware vSphere ESXi
  • Observing the following alarm in the NSX UI: Edge NIC out of receive / transmit buffer alarm
    • Edge NIC out of receive buffer
    • Edge NIC out of transmit buffer
  • After or during a large file transfer flowing through NSX Edge Node data path, the above alarm shows
  • NSX Edge Nodes are Large form factor size or smaller
  • Similar NSX Edge Node logging is observed: Edge NIC fp-eth0 receive ring buffer has overflowed by 6.785233% on Edge node ########-####-####-####-############. The missed packet count is 2270695 and processed packet count is 31194550.
  • Tier1 gateways deployed by Tanzu/VKS are all active on a single NSX Edge Node
VMware NSX
Multiple factors in this scenario fall under the cause:
Follow the resolution steps from the following three KBs:
