Copying a project does not work - Troubleshooting
Article ID: 422612
Clarity PPM On Premise Clarity PPM SaaS Clarity FedRAMP
Trying to copy a project in MUX and getting an error Copy Failed - API-1018 : Could not process the request. Refer to error code for more details
All Supported Clarity Releases
  • Create a new project with no tasks or assignments, check if you are able to copy it
  • Try copying from Project Timeline - right click - Copy with Children  or Project Grid - right click - Copy. Note if the error messages differ
  • Make sure there are no processes starting on that project
  • Disable Audit on the project/task/assignment, see if that helps
  • Check all subobjects - any that get automatically created
  • Check in Studio for any hidden subobject pages
