Error log: Dec 1 15:14:29:427 [14236] 0 de: CreateSession - ERROR: Code=0x80004005 Source=Microsoft SQL Server Native Client 11.0 Description=Login timeout expiredDec 1 15:14:29:427 [14236] 0 de: CreateSession - ERROR: Code=0x80004005 Source=Microsoft SQL Server Native Client 11.0 Description=A network-related or instance-specific error has occurred while establishing a connection to SQL Server. Server is not found or not accessible. Check if instance name is correct and if SQL Server is configured to allow remote connections. For more information see SQL Server Books Online.Dec 1 15:14:29:427 [14236] 0 de: CreateSession - ERROR: Code=0x80004005 Source=Microsoft SQL Server Native Client 11.0 Description=TCP Provider: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.DX UIM 23.4.
Environment / Network issues can cause this - Not a DX UIM issue
Similar issues has been observed on environment that have suffered:
Windows enforces a TIME_WAIT delay before a local port can be reused.
If an application is opening/closing many connections rapidly (e.g., API polling, database connections, sockets, HTTP clients), this happens:
All ephemeral ports get used up
Ports stay “locked” in TIME_WAIT
System cannot assign new ones → Error 4227
