./start.sh -d -t 825
| CBM_CORFU | WARNING : ***.***.***.*** : Certificate CBM_CORFU is | Certificate of service type: 'CBM_CORFU' will be replaced. |
| | expiring in ** days | Certificate of service type: 'CBM_CORFU' will be replaced. |
| | expiring in ** days | |
| | WARNING : ***.***.***.*** : Certificate CBM_CORFU is | |
./start.sh -t 825 -r validation_config_recovery_mode.yaml
VMware NSX 4.1
In NSX 4.1, CORFU_SERVER should be specified, but in the CARR dry run, CBM_CORFU was specified.
This will be fixed in a future release of CARR.
Workaround:
If run CARR with "-r validation_config_recovery_mode.yaml" then CBM_CORFU is not updated, re-run CARR without "-r validation_config_recovery_mode.yaml" option.
# start.sh -t 825
