Maintenance mode action request returned: 500
---Edge Reboot---systemd 1 - - Starting Docker Application Container Engine...systemd 1 - - Starting LSB: VMware File Integrity Checker...systemd 1 - - Starting Edge DNS...... ... dockerd 3054 - - time="Time_Stamp" level=info msg="Starting up"... ...dockerd 3054 - - time="Time_Stamp" level=info msg="API listen on /run/docker.sock"
--- edge-images-load starts ---
edge-images-load.sh 4099 - - + BUNDLE=/opt/vmware/nsx-edge/nsx-edge-images/images.tar.gzedge-images-load.sh 4101 - - + date --utc --iso-8601=secondsedge-images-load.sh 4099 - - + TIMESTAMP=Time_Stampedge-images-load.sh 4099 - - + LOG=/var/log/nsx-edge-images-load.Time_Stamp.logedge-images-load.sh 4099 - - + [ -f /opt/vmware/nsx-edge/nsx-edge-images/images.tar.gz ]edge-images-load.sh 4099 - - + mount --make-shared /
--- edge-images-tag.sh does not start ---
VMware NSX
The docker container images need to be imported before the Datapath, NSXA, NSD, etc, services can be started before exiting maintenance mode.
While the slow infra/storage performance would cause the processes to either slow down significantly or fail entirely.
Contact hardware vendor to investigate the infra/storage performance
