Power filter on Capacity Overiew portlet does not work
Article ID: 4201
Clarity PPM SaaS Clarity PPM On Premise
Unable to use the Power Filter functionality on the Capacity Overview portlet. When clicking the 'Build Power Filter' link on the Capacity Overview portlet, receive error: 'There are no fields available for power filter use.'
Steps to Reproduce:
  1. Enable the Power Filter option on the Capacity Overview portlet:
  • In PPM go to Administration->Portlets
  • Click on the Capacity Overview portlet
  • Select 'Layout' from the 'List Filter Section' tab
  • Check 'Allow Power Filter' check box and then click 'Save and Return'
    2.  In PPM go to Home->Resource Management->Capacity Overview
    3.   Click the '+' icon next to the Capacity Overview portlet to expand the filter section (if not expanded already)
    4.   Click the 'Build Power Filter' link
Expected Result: A 'Power Filter' configuration page appears
Actual Result: Receive message: 'Alert: There are no fields available for power filter use.'
Applies to all supported PAS environments for specified releases.
This is caused by: CLRT-75476
This is working as designed, power filter capability is currently not available in the Capacity Overview portlet.
