Virtual machines are unable to communicate with each other, after migrating from vSwitch to Distributed switch (vDS).
VMware vSphere ESX all versions
The issue is due to configuration mismatch in the Link Aggregation Control Protocol (LACP) between the virtual switch layer and the physical network layer.
If LACP is configured on distributed switch, make sure to implement LACP on the physical switches for the traffic to flow correctly.
