The load balancing capability of an ESXi virtual switch, configured in the Teaming and failover settings, offers a number of load balancing options. One of these, Route based on IP hash, requires a matching configuration at the upstream switch connect to the host.
An incorrect load balancing configuration can exhibit the following issues:
The Route based on IP hash load balancing algorithm requires static EtherChannel on the uplink switch. If this option was selected but a corresponding configuration is not present on the upstream switch, issues such as packet loss can arise.
Another load balancing feature, Link Aggregation Control Protocol (LACP), requires a matching configuration on the uplink switch to take effect. Furthermore, switch vendors have differing implementations of LACP which can sometimes result in unexpected behavior.
Load balancing across uplinks when the uplinks do not have identical VLAN access, lead to different network segments or topologies, or are split across two or more physical switches where the VPC peering link is down or having issues will also result in network degradation.
The partial unreachability and packet loss behavior described above can also be exhibited when the load balancing is configured correctly but one or more uplinks are degraded, due to a physical connection problem for example.
When partial unreachability or intermittent packet loss is observed,
esxcli network vswitch dvs vmware lacp status get
