ConnectAll Orphan management not running due to "Unexpected error occurred in scheduled task" error
Article ID: 419231
ConnectAll On-Prem ConnectALL
Several orphan management plans were scheduled to run daily, but items were not being cleaned up via orphan management.
We see the following error in the Orphan log: Unexpected error occurred in scheduled task
Found in Release 3.9.1
Steps to Reproduce:
  1. Set up Orphan Management job
Expected Results:
  • The job runs at the expected time
Actual Results:
  • The job doesn't run at all
Workaround:
  • Start the Orphan job manually.
On Premise.
DE178520
Fixed in release 4.0.1 patch.
