K8s job does not fail when using an incorrect image name
Article ID: 418034
CA Automic Workload Automation - Automation Engine
It is observed that when you start a K8s job with an incorrect image name, the job remains active on the Automic side, but in K8s it fails.
This is expected behavior as the K8s Integration manages a job, not a pod. Note that a job can start multiple pods, of which some may fail, while others run correctly. These individual statuses are not tracked.
In case the job only launches a single pod, a possible workaround could be using the parameter activeDeadlineSeconds
For example:
apiVersion: batch/v1
kind: Job
metadata:
spec:
  activeDeadlineSeconds: 10
  template:
    spec:
      containers:
      - name: busybox-job
        image: busybox1234
        command: ["sh", "-c", "echo Hello, Kubernetes Job! && sleep 30"]
      restartPolicy: Never
In this definition, the pod will fail because of the non-existing image name, but the job will not remain active on the Automic side because no active pod is detected.
