Cluster sizing and flow metrics not available after upgrading to SSP 5.1
Article ID: 417067
VMware vDefend Firewall VMware vDefend Firewall with Advanced Threat Prevention
As part of SSP 5.1, there is new metrics reported for Transport Nodes/Clusters.
After upgrading from SSP 5.0 to 5.1, in the SSP UI, after navigating to  System → Overview, the "FLOW PROCESSING CAPACITY" panel for "Observed Flows" will show an error "No metrics are available for the selected hosts and clusters" as per below screenshots.
  • Cluster sizing job return "No metrics are available for the selected hosts and clusters." even after minimum required flow metrics collection period has passed.
  • Flow trends graphs will show no flow metrics data.
  • Host capacity page will not show metrics against hosts, clusters and prioritized collections.
 Error snapshot from the UI :
SSP 5.1
The issue occurs due to a schema mismatch in the Transport Node (TN) flow metrics tables after upgrade.
SSP 5.1 introduces new derived flow metrics, which add additional columns to the metrics tables.
The existing tables created before the upgrade do not contain these new columns for the newly added derived metrics.
After the upgrade, the metrics query service in 5.1 expects these columns to be present, which leads to query errors.
This situation continues until the next rollup process runs. The rollup process periodically creates new metric tables with the updated 5.1 schema.
Once these new tables are created, the issue will be resolved automatically.
SSP setups upgraded to 5.1 will experience a gap in TN metrics until the new table is created after the rollup.
The time to recover this data gap depends on selected request duration:
  • Last 1 Hour - 2 days (Current & Next day)
  • Last 12/ 24 Hours  - 2 weeks(Current & Next week)
  • Last 1 Week/ 2 Weeks/ 2 Months - 2 years (Current & Next year)
Contact Broadcom Support to update metrics DB table with the necessary fields to start receiving flow metrics immediately.
NOTE : This issue is fixed in SSP 5.1.1 release of SSP.
