Power On of VM fails with "00:50:56:##:##:## is not a valid VPX-assigned Ethernet Address. Failed to start the virtual machine."
Article ID: 416958
VMware vCenter Server
  • Virtual Machine power-on intermittently fails after a restore from a third-party backup solution to a different vCenter with following error on vCenter UI:
    "00:50:56:##:##:## is not a valid VPX-assigned Ethernet Address. Failed to start the virtual machine. Module DevicePowerOn power failed. Could not set up "macAddress" for ethernet0. Invalid MAC address specified."
  • less var/log/vmware/vpxd/vpxd.log:
    • Get exception while executing action vpx.vmprov.PowerOnVm:
      --> (vim.fault.GenericVmConfigFault) {
      --> faultMessage = (vmodl.LocalizableMessage) [
      --> (vmodl.LocalizableMessage) {
      --> key = "msg.mac.badVpxAddress",
      --> arg = (vmodl.KeyAnyValue) [
      --> (vmodl.KeyAnyValue) {
      --> key = "1",
      --> value = "00:50:56:##:##:##"
      --> message = "Invalid VPX-assigned Ethernet address: '00:50:56:##:##:##'. "
      --> key = "msg.mac.invalidAddress",
      --> message = "Invalid MAC address specified. ",
      --> key = "msg.mac.setupMacAddressFailed",
      --> key = "1",
      --> value = "0"
      --> message = "Could not set up 'macAddress' for 'ethernetX'."
      --> key = "msg.moduletable.powerOnFailed",
      --> key = "1",
      --> value = "DevicePowerOn"
      --> message = "Module 'DevicePowerOn' power on failed. "
      --> key = "msg.vmx.poweron.failed",
      --> message = "Failed to start the virtual machine.",
      --> reason = "Invalid VPX-assigned Ethernet address: '00:50:56:##:##:##'. ",
      --> msg = "Invalid VPX-assigned Ethernet address: '00:50:56:##:##:##'.
The error is caused by a mismatch between the MAC address type and its assignment method—specifically, a static VMware-assigned MAC address is incorrectly labeled as a vCenter-assigned "vpx" type, leading to an invalid VM configuration.
The MAC address configuration has to be changed to ensure consistency between the address type and assigned value.
  • Option 1 (Recommended): Change the address type to “static”
    • This preserves the existing MAC address and avoids guest OS network configuration issues.
      • This update can be performed in two ways:
        • Using VIM API (recommended, as it is controlled and less error-prone).
        • Editing the VMX file directly with a text editor (only if API changes are not feasible).
  • Option 2: Change the MAC address to a valid VPX-assigned one
    • Assign a MAC that begins with 00:0C:29.
    • Note:
      • Modify the .vmx file directly while the VM is registered in vCenter.
      • Reload or re-register the VM with manual edits unless no other API-based method is available.
