Article ID: 416436
Feedback
Subscribe
Show More
Show Less
While running this command: nslookup -type=SRV _ldap._tcp.dc._msdcs.example.com from the KB Authentication Source not switching if DC decommissioned in Aria Operations , the following result is returned:
;; communications error to ::1#53 connection refused;; communications error to 127.0.0.1#53 connection refused;; no servers could be reached
VMware Aria Operations 8.18.x
Check if any of the Aria operations analytics node(s) is/are missing the vApp Options properties in vCenter.
If any of the vApp Options properties are missing follow the steps below:
Take Snapshot Creation in VMware Aria Operations
On the affected analytic node, follow the steps from KB Restoring vApp properties in VMware Aria Operations 8.14 and Later
After fixing the vApp Options properties on Aria Operations node(s), bring the cluster online, in the user interface the option that display the DC host list or auto option will now be available in AD controller configuration.
