VM Power On/Off Operation not Triggered from vSphere Client
Article ID: 416207
VMware vCenter Server VMware vSphere ESXi
When an operator attempts to power on or power off a virtual machine from the vSphere Client
  • No corresponding task is initiated
  • No relevant log entries are found on either the ESXi host or the vCenter Server
VMware vCenter Server 8
The issue occurs when using an unsupported web browser version.
Update the web browser to a supported version and retry the operation.
Check vSphere Client Software Requirements
