Solution and Patches for Advanced Authentication product
Article ID: 41423
Updated On: 01-04-2022
CA Advanced Authentication CA Strong Authentication CA Risk Authentication CA Advanced Authentication - Strong Authentication (AuthMinder / WebFort)
Where can I find the solutions and patches for CA Strong Authentication product?
Release: 9.x
Component: AuthMinder(Arcot WebFort)
RiskMinder(Arcot RiskFort)
Solutions and patches are available on the support site. Please follow the below steps to access the page.
1. Login to https://support.broadcom.com/ website with credentials.
2. Go to Symantec Enterprise Security ->Download Management and then click on Advanced Authentication product.
3. Go to Solution Download page, Under Download center expanded section click on Published Solutions
4. Choose a release for which patches are required from "Select A Release" drop down.
5. Click on the "GO" button.
6. It will list all the patches available for the base version selected earlier and for the all the available OS platforms, please download as per your environment.
