Host connection and power state during backup
Article ID: 413916
VMware vSphere ESXi
Symptoms:
  • vCenter reported "Host connection and power state" Alarm on host
  • Backup is running on the host and may report error on backup software
  • Hostd crashs and dumps are created before the alarm is reported
  • Huge number of Blklistsvc log over the backing up VM can be found in hostd
    Hostd[45076243]: [Originator@6876 sub=Blklistsvc opID=xxxx sid=xxxx user=vpxuser:<BACKUP-USER>] Block list request received for snapshot <snapshot-name>, disk [] <a vmdk>, r/w: no, session xxxx
    Hostd[45076243]: [Originator@6876 sub=DiskLib opID=xxxx sid=xxxx user=vpxuser:<BACKUP-USER>] DISKLIB-VMFS  : "<a vmdk>" : failed to open (Reached the host's limit for open files): Directory open failed on '<VM PATH>': Too many open files (24). Type 3
    Hostd[45076243]: [Originator@6876 sub=DiskLib opID=xxxx sid=xxxx user=vpxuser:<BACKUP-USER>] DISKLIB-LINK  : DiskLinkOpen: Failed to open '<a vmdk>': : Reached the host's limit for open files
    Hostd[45076243]: [Originator@6876 sub=DiskLib opID=xxxx sid=xxxx user=vpxuser:<BACKUP-USER>] DISKLIB-CHAIN : DiskChainOpen: "<a vmdk>": failed to open: Reached the host's limit for open files.
    Hostd[45076243]: [Originator@6876 sub=DiskLib opID=xxxx sid=xxxx user=vpxuser:<BACKUP-USER>] DISKLIB-LIB   : Failed to open '<a vmdk>' with flags 0xe Reached the host's limit for open files (40).
    Hostd[45076243]: [Originator@6876 sub=Blklistsvc opID=xxxx sid=xxxx user=vpxuser:<BACKUP-USER>] Failed to open virtual disk: [] /<a vmdk> Reached the host's limit for open files 40.
    Hostd[45076243]: [Originator@6876 sub=Blklistsvc opID=xxxx sid=xxxx user=vpxuser:<BACKUP-USER>] Destructor for Lease <snapshot-name>-lease-3181 called
ESXi
Too Many directly API call DiskManager.acquireLeaseExt from third-party software to the same disk.
Restart hostd and vpxa service on the issue host.
