This article offers a detailed walkthrough on setting up Power BI for report generation, with a particular emphasis on its integration with the CASM Reporting API. It details the essential procedures for utilizing Power BI's visualization features to construct reports based on SDM out-of-the-box reports.
This document provides an example for the "Change Orders by Category Report" out-of-the-box report. You can use it as a base for other reports (OOTB or custom), where some items will differ, like the value set for X-Report-Code, Result items, etc.
Service Desk Manager 17.4 RU4 and later
Microsoft Power BI 2.x
1. Log into Power BI | Blank Report
2. Click on Get Data | Blank Query | Rename the query to GetAccessToken in the right pane under "Properties"
3. Click on the "Advanced Editor" on the menu bar | Copy and paste the following code:
(tokenUrl as text, authHeader as text) =>let headers = [ #"Authorization" = authHeader, #"Content-Type" = "application/json" ], body = Text.ToBinary("{}"), response = Json.Document(Web.Contents(tokenUrl, [ Headers = headers, Content = body ])), access_token = response[accessToken] // Adjust key name as per casm json response for access token.in access_token
4. Click on the "Close & Apply" button
5. Click on Get Data | Blank Query | Rename the query to GetReportDataByCode in the right pane under "Properties"
6. Click on the "Advanced Editor" on the menu bar
7. Copy the following code to a text editor:
let //Get token using the function defined in step1 and get the base 64 encoded username+password. You can use swagger to grab this and it's one time definition. token = GetAccessToken("http:///CASMReports/reports/v1/access", "Basic <BASE 64 encoded username+password>"),<SDM hostname>:<Report API port>
// API call to get the report data using token + report code url = "http://<SDM hostname>:<Report API port>/CASMReports/reports/v1/getReport", rawResponse = Web.Contents(url, [ Headers = [ #"X-AccessToken" = token, #"X-Report-Code" = "Change_Change_Orders_by_Category_Report", #"accept" = "*/*", #"Accept" = "application/json" ] ]),
// Parse JSON as needed if required. jsonResponse = Json.Document(rawResponse), resultsArray = jsonResponse[results],
resultsTable = Table.FromList(resultsArray, Splitter.SplitByNothing(), null, null, ExtraValues.Error), expandedTable = Table.ExpandRecordColumn(resultsTable, "Column1", { "countall_casd_chg_total_change", "casd_chg_category_symbol" }, { "Count", "Category" })in expandedTable
Note: Replace the following items with the values from your environment:
7.a: Replace "" with your SDM hostname where the CASM Report API is running and the Tomcat port being used to deploy this API.http:///CASMReports/reports/v1/access<SDM hostname>:<Report API port>
7.b: Replace "<BASE 64 encoded username+password>" with the Base 64 code for the username and password that is generated via Swagger or some other external tool to encode to Base 64.
7.c: Replace "http://" with your SDM hostname where the CASM Report API is running and the Tomcat port being used to deploy this API.<SDM hostname>:<Report API port>/CASMReports/reports/v1/getReport
8. Copy the updated code and paste it into the Advanced Editor | Click on the "Close & Apply" button
9. Now you'll see the GetReportDataByCode query under Data
10. Create the report.
Example 1: Click on Table under Visualizations | Click on the checkbox next to the items you want to add to the table.
Example 2: Click on Pie Chart under Visualizations | Click on the checkbox next to the items you want to add to the Chart.
