After applying Maintenance for OM Web Viewer 12.1, the build number remains the same.
Article ID: 41302
Output Management Web Viewer
After applying Maintenance for Output Management Web Viewer 12.1, the build number remains the same.
The log for the install of the maintenance, located in the CA_OM_Web_Viewer/uninstaller/Logs directory showed the following error:
ERROR - build.xml:114: Error while expanding /tmp/629488.tmp/CAOMWebViewer12.war
Output Management Web Viewer 12.1 for Linux or USS
There is a lack of temp space ...specifically in the system default /tmp folder
  1. Manually remove any folders that may have been left from the failed install.
  2. Add a command-line argument to define an alternate temporary location for the install.
The System Properties you need to set are:   -Dlax.nl.env.iatempdir and java.io.tmpdir
Here is an example:
    java -Dlax.nl.env.iatempdir=<Desired location>/tmp  -Djava.io.tmpdir=<Desired location>/tmp -jar CA_OM_WebViewer_12_Updt.jar
Where <Desired location>/tmp is your new temporary folder with at least 500MB (Update installer) of free space.
