BGP flapping from T0 to Cisco ACI after NSX Edge node vMotioned to newly added host in vSphere Cluster
Cisco ACI requires a BGP profile applied to each ESXi host uplink to the Cisco ACI fabric (TOR switch)
NSX Edge Node VM was vMotioned to a newly added host to the cluster right before the BGP flap/outage occurred
VMware NSX
Cisco ACI BGP profile is missing on the ESXi host uplink to the Cisco ACI fabric (TOR switch)
Workarounds:
vMotion the NSX Edge Node VM back to original host where the BGP peering was working previously
Configure BGP profile on Cisco ACI fabric interface connected to the ESXi host in question where BGP peering was lost after vMotion
