Monitor page for Edge Transport node is not loading, you see a spinning circle
Article ID: 412207
VMware NSX
  • When trying to access the monitor page for  edge nodes in NSX UI, you see a spinning circle but does not display any statistics.
    1) System → Fabric → Nodes → Edge Transport Nodes
    2) Select the edge node
    3) Under Monitor → Network Interface
  • Using different browsers and PCs exhibit the same behavior.
  • "start search resync all" has been executed on all the NSX Manager nodes and the issue still persists
VMware NSX
  • Perform a rolling reboot of all NSX managers
  • Wait for about 15 minutes for the page to load
If the page does not load after performing the steps above, please open a support case with Broadcom Support
For more information, see Creating and managing Broadcom support cases.
