Connectivity lost when Edge failover occurs with only static route in use.
Article ID: 410370
VMware NSX
  • Northbound connectivity is lost for traffic through a Tier-0 that relies on a static route after a failover active to standby nodes.
  • NSX traceflow from southbound VM's to external IPs shows "No Route" in the Tier-0 even though static route is apparently configured.
  • Static route has scope set on next hop.
  • When validating the static routes presence on the Edge node via CLI the static route is only present on one node (that is now standby). The active node will be missing the required / expected routes. To verify the presence of the route on the edge nodes the following can be done
    1. SSH to Edge node housing the Tier 0.
    2. Login as admin.
    3. Run "get logical-routers" .
    4. Identify the SR of the Tier-0 and note its VRF number.
    5. Run "vrf <VRF ID obtained in step 4>.
    6. Run "get routes".
    7. Within the routes listed, static route required for northbound connectivity is missing on only one node.
VMware NSX
VMware NSX-T Data Center
This issue may be caused by the static route having been configured with a scope set for its next hop. When the next hop value is created it can have a scope defined, this scope will set where the static route is applied.
A scope can be an interface, a gateway, an IPSec session, or a segment. If a value is set here such as an interface it needs to be applied to an interface on both edge nodes. If only one interface is selected, such as an interface on edge 1 then edge 2 will not have the static route realised. In the below image, only an interface from edge 2 is in the scope so edge 1 will not have the static route pushed to it. Meaning when edge 2 is failed over to edge 1, no valid realisation interface is present so the static route is not applied.
  1. Log in to the NSX Manager UI.
  2. Navigate to Networking > Tier-0 Gateways.
  3. Edit the affected Tier-0 Gateway and select Routing > Static Routes.
  4. Edit the failing static route.
  5. In the Next Hops configuration, perform one of the following:
    • Remove the interface scope entirely to allow the route to be dynamically applied to all available external interfaces.
    • Ensure the scope includes the appropriate interfaces for both Edge nodes in the HA cluster.
  6. Save the configuration and verify connectivity via Traceflow.
