The docker registry that's started as a podman pod during the prepare process throws the error message "lsetxattr: Operation not permitted"
Smarts TCSA 2.x
The filesystem that is created is not suitable to run the container.
Since this is an infra issue, customer to explore the corrective action to provide a suitable filesystem for the CPN nodes
