"There was a problem connecting to the server." message appears when attempting to access the xFlow login screen.
Article ID: 4100
CA IT Asset Manager CA IT Asset Manager Asset Portfolio Management CA Service Management - Asset Portfolio Management ASSET PORTFOLIO MGMT- SERVER CA Service Desk Manager CA Service Management - Service Desk Manager CA Service Catalog Process Automation Manager CA Process Automation Base
The below message appears when attempting to access the xFlow interface from a remote workstation.  The error does not appear when attempting to access the xFlow interface from the CA Service Desk Manager (CA SDM) server itself.
"There was a problem connecting to the server. Refresh the page and try again. Please contact the system administrator if the problem persists."
Service Desk Manager 14.x and 17.x
All Supported Operating Systems
When there is a DNS/name resolution problem for the CA SDM server hostname, this behavior occurs. Even if a ping is successful between the remote workstation and the CA SDM server, DNS/name resolution of the CA SDM server hostname must work correctly
As a quick check, it is best to set the name resolution of the SDM server hostname in the hosts file located in the 'C:\Windows\System32\drivers\etc' directory on the SDM server.
If the problem still occurs even after DNS/name resolution is set appropriately, take a Fiddler trace while reproducing the problem and contact Broadcom Support for further assistance.
17.4 documentation:  Troubleshooting xFlow Interface
