Connection to storage system fails after upgrading SRM and SRA
Article ID: 409949
VMware Live Recovery
You receive the following error while editing the Local Array Manager configuration after upgrading SRM and SRA:
Error: x509 cannot validate certificate
VLSR
Invalid or expired certificate on the storage system.
Contact storage system vendor to generate new certificates on the storage system (procedure is vendor specific).
This is not a VMware certificate.
