Does CA Automation Point 11.5 support ooRexx 4.2.0 64-bit ?
Article ID: 40957
CA Automation Point
Question:
Does CA Automation Point 11.5 SP00/SP01 support ooRexx 4.2.0 64-bit ?
Answer:
NO, the Windows 64bit version of OORexx is not supported.
Additional Information:
With CA Automation Pount 11.5 SP00/SP01 we deliver the ooRexx 32-bit version and that's tested and supported.
Release: AP327020100-11.5-Automation Point-3270/5250 Interface Option
Component:
