vCenter Alarm “Host Connection and Power State” Triggered Due to hostd Service Exiting with Code 127
Article ID: 409290
VMware vSphere ESXi
  • ESXi host briefly shows as 'Not responding' in the vSphere Client but quickly returns to normal.
  • Alarm 'Host Connection and Power State' is triggered.
  • /var/run/log/syslog.log reports hostd exited with code 127.
YYYY-MM-DDTHH:MM:SS.SSSZ watchdog-hostd[xx]: ‘hostd ++min=0,swapscope=system’ exited after xx seconds 127
  • /var/run/log/hostd.log reports dynamic libraries are being loaded just before the restart.
YYYY-MM-DDTHH:MM:SS.SSSZ info hostd[xx] [Originator@6876 sub=Libs opID=xxxxxxxx] PluginLdr_Load: Loaded plugin 'libvmiof-disk-spm.so' from '/usr/lib64/vmware/plugin/libvmiof-disk-spm.so'
YYYY-MM-DDTHH:MM:SS.SSSZ info hostd[xx] [Originator@6876 sub=Libs opID=xxxxxxxx] PluginLdr_Load: Loaded plugin 'libvmiof-disk-vmwarevmcrypt.so' from '/usr/lib64/vmware/plugin/libvmiof-disk-vmwarevmcrypt.so'
  • Note: The libraries loaded may vary and are not always the same as shown above.
  • Temporary disconnections of the ESXi host from vCenter Server may occur.
  • VMware vSphere ESXi 7.0.x
  • VMware vSphere ESXi 8.0.x
  • This issue originates from a bug in older versions of the GNU C Library (glibc).
  • Under specific conditions—particularly when dynamic libraries are loaded simultaneously with thread creation and termination—a rare race condition may occur.
  • This race condition can cause the hostd service to exit unexpectedly with exit code 127.
  • This issue has been resolved in ESXi 8.0 Update 2 (U2) and later releases.
  • There is currently no workaround available for affected earlier versions.
  • Although the hostd process may crash unexpectedly due to this issue, it is automatically restarted by the system.
  • As a result, there is no impact on running virtual machines during such events.
