Symptom :
envoy.log
2023-12-15T13:33:13.036Z warning envoy[#######] [Originator@6876 sub=filter] [######] local https connections exceed max allowed: 2048
2023-12-15T13:33:13.036Z warning envoy[#######] [Originator@6876 sub=filter] [######] closing connection TCP<127.0.0.1:41032, 127.0.0.1:8084>
Remote connections from other VMware solutions or from 3rd party services may become exhausted despite solution to increase connections has ben applied described in KB344920
VCenter 8.0U2
VUM connections limit which can't be changed via the rhttpproxy configuration file.
Remove the connection limit for the VUM port 8084.
Note: Do backup file before change anything
1 Remove the envoy.filters.network.vmware filter from /etc/vmware-rhttpproxy/endpoints.conf.d/edge_vum_8084_https.json
"name": "envoy.filters.network.vmware"
2 Restart rhttpproxy service to apply changes
service-control --stop vmware-rhttpproxy
service-control --start vmware-rhttpproxy
Note: This is not recommended and can be considered a security issue.
The fix for this issue is part of 8.0.3.
