After Edge node replacement, packets drops experienced
Article ID: 408056
VMware NSX
VMware vSphere ESXi
- NSX Edge VM(s) in Read-only mode due to datastore outage and had to be replaced
- Edge nodes have been replaced successfully but packet drops experienced
- Replaced Edge nodes are no longer part of the edge cluster
- Replaced edge nodes have not been deleted
- Trace flow shows the replaced edge node(s) in the data path
Delete the replaced edge nodes
Feedback
thumb_up
Yes
thumb_down
No
