To receive Netflow or sFlow from a third party "physical" device, you must have three elements:
- Deploy a dedicated Collector appliance OVA into vCenter.
- Add a Physical Flow Collector (Netflow, sFlow) data source in GUI and associate it with the dedicated Collector (step 1).
- Configure your device to export flows to the dedicated Collector (step 1).
Use the following steps to complete the three elements listed above:
- Login to VCF Operations for Networks GUI using username admin@local
- From the left navigation pane, go to Settings > Accounts and Data Sources.
- Click Add Source.
- Under Flows, select Physical Flow Collector (Netflow, sFlow)
Note: Netflows and sFlows are accepted only on a dedicated Physical Flow Collector data source and appliance.
- On Add a new Physical Account or Source page, click Add Collector VM button.
- The Add a new Operations for Networks Data Collector virtual appliance window is displayed.
Click Copy button to copy the shared secret needed to import the collector service ova in your VMware vCenter
Follow the instructions in Deployment Using vSphere Web Client to deploy a new Collector VM and provide the Shared Secret copied in this step.
Click Close button.
- Click Done.
- In the Nickname text box, enter a nickname.
- In the Notes text box, add a note if necessary.
- Click Submit.
- Once the Data Source is configured, enable Netflow or sFlow export on your third party device (e.g. the Cisco Nexus 9K switch) and point it to the newly deployed dedicated physical flow collector's IP address.
Note: You may need to wait for a couple of hours (at max 2-3 hours) for each device for the flow number information to be seen in VCF Operations for Networks.
To speak with a customer representative or a Support Engineer see Contact Support. Scroll to the bottom of the page and click on your respective region.
