A scheduled task ithat allows multiple concurrernt instances s being executed but keeps timing out with the results not appearing in the activity center. When inspecting the job name assigned to the scheduled task, the job name may not appear.
Aria Config 8.14+
Take a screenshot of the scheduled job configuration
Delete the scheduled job
Manually create a new copy of the scheduled job ensuring that it references the correct job name
