Recommended Maintenance for running Roscoe with JCLCheck
Article ID: 40540
Updated On: 07-14-2023
JCLCheck Workload Automation Roscoe
What are the recommended JCLCheck maintenance to work with Roscoe?
Release: 12.0
Component: JCLCheck Workload Automation
                     JCLCheck Common Component
These are the recommended JCLCheck PTFs:
SO08139 - ROSCOE - CAY6079E ISSUE FOR DATASET IN SECOND
RO98046 - JCLCHECK S0C4 ABEND EXECUTING IN ROSCOE ENVIRONMENT
RO96121 - SET LAST/MAX CC PROPAGATION OPTION
RO96120 - SET LAST/MAX CC PROPAGATION OPTION
RO82087 - MESSAGE CAY6595I IMPROPERLY ISSUED-ROSCOE
RO81532 - ROSCOE HANG AFTER EXECUTING RPF PROGRAM
RO80575 - S878 ABEND EXECUTING ROSCOE AND JCLCHECK
RO75434 - S0C4 ABEND IN MODULE CAZ2SYNM
LU07229  - COMMON COMPONENT IN ROSCOE WITH AUTOPROC - INTERMITTENT S0C4
