VMs associated with vSAN default Storage policy are marked as "Out of Date".
The vSAN default Storage policy was displaying as incompatible with the vSAN datastore at the time of VM creation failure.
When attempting to power on VM you will see errors creating vSWAP object.
VMware vSAN 7.x
VMware vSAN 8.x
The applied vSAN Storage Policy's or the datastore's default policy's Space efficiency setting is set to "Compression only" or "Deduplication and compression".
Due to this, when creating an object in a vSAN Standard cluster with Space efficiency policy set to "Compression only" or "Deduplication and compression", the object creation will fail with "Invalid virtual machine configuration. Object policy is not compatible with datastore space efficiency policy configured on the cluster" error message.
####-##-##T##:##:##.###+##:## warning vpxd[08035] [Originator@6876 sub=Vmomi opID=mck6abvq-699520-auto-ezr5-h5:70301364-58] VMOMI activation LRO failed; <<########-####-####-####-f7d35194d1a6, <TCP '127.#.#.# :
####'>, <TCP '127.#.#.# : 57318'>>, group-v4, vim.Folder.createVm>, N3Vim5Fault16CannotCreateFile9ExceptionE(Fault cause: vim.fault.CannotCreateFile
--> [context]########[/context]
2025-07-09T15:16:29.024+05:30 info vpxd[08035] [Originator@6876 sub=vpxLro opID=mck6abvq-699520-auto-ezr5-h5:70301364-58] [VpxLRO] -- FINISH task-873685
2025-07-09T15:16:29.025+05:30 info vpxd[08035] [Originator@6876 sub=Default opID=mck6abvq-699520-auto-ezr5-h5:70301364-58] [VpxLRO] -- ERROR task-873685 -- group-v4 -- vim.Folder.createVm: vim.fault.CannotCreate
key = "vob.vsanprovider.object.creation.failed",
arg = <unset>,
message = "Failed to create object."
(vmodl.LocalizableMessage) {
key = "vob.vsan.clomd.incompatibleDatastoreSpaceEfficiency",
-arg = <unset>,
message = "Object policy is not compatible with datastore space efficiency policy configured on the cluster"
To resolve this issue change the vSAN Storage policy's Space Efficiency parameter to "No preference".
Navigate to vSphere Client > Menu > Policies and Profiles > VM Storage Policies > Select the Policy to be updated > Edit:
As a result, the chosen datastore will be used by default for space efficiency.
Note:
