Channel filter does not work for .war and .ear files.
Article ID: 403473
Data Loss Prevention Data Loss Prevention Core Package
You specified an exception to ignore files with the .war or .ear extension, so DLP should not scan those files; however, scanning is still being performed.
Those file types are essentially archive files, and DLP does not really look at the extension but rather at the file structure; therefore, it considers them as .zip files.
Create a filter for .zip files. If possible, use a specific path to narrow down the scope, in case you do not want to exclude all .zip files from scanning.
Filter by File Properties settings
