Metric Selector not showing metrics for vApps/VMs in Aria Operations plugin after Chargeback migration
Article ID: 402911
Navigating to Metering - Metric Selector in the Operations Plugin in vCloud Director displays the below for vApps/Virtual Machines:
No metrics to select
Aria Operations 8.18.x
Metrics for Chargeback are disabled in Aria Operations
To resolve this issue, please follow the below steps:
  • Login to Aria Operations UI page
  • Navigate to Administration - Control Panel - Chargeback - Manage Metrics
  • Select Object type for:
    • vApps: VMware Cloud Director Adapter - vApp
    • Virtual Machines: vCenter - Virtual Machine
  • Change the State from Deactivated to Activated for the Metrics/Properties you want to see under Metric Selector
  • Click Save and check the Metric Selector on VCD to view the Metrics
