Below mentioned 3 issues are now fixed in Aria Operations for Networks 6.14 Patch 8, Build number 1749832225 :
1. Latency Profile enabled on Aria Operations for Networks GUI when disabled does not get removed from NSXT Transport Zones with the BFD Profile.
2. An IllegalArgumentException is seen from logs at location /var/log/arkin/collector/ while processing the security policies, refer to log entry below:
java.lang.IllegalArgumentException: Comparison method violates its general contract_
at java.util.TimSort.mergeHi(TimSort.java:903) _[_:_]
at java.util.TimSort.mergeAt(TimSort.java:520) _[_:_]
at java.util.TimSort.mergeForceCollapse(TimSort.java:461) _[_:_]
at java.util.TimSort.sort(TimSort.java:254) _[_:_]
at java.util.Arrays.sort(Arrays.java:1515) _[_:_]
at java.util.ArrayList.sort(ArrayList.java:1750) _[_:_]
at com.vnera.dataproviders.core.impl.vmware.policymanager.tasks.datafetchers.PolicyManagerFirewallPolicyRulesFetcher.getFirewallPolicies
3. Incomplete policy firewall rule SDM causes to toggle realized entity and email Notifications From Stale Alerts, Refer to GUI Screenshot showing Email alert notifications:
In above you see Alert shows very older time stamp and email notification is very recent.
From collector logs at location /var/log/arkin/collector
com.vnera.dataproviders.core.common.impl.dataprovider.utils.exceptions.HttpException: Could not get response for /policy/api/v1/infra/realized-state/realized-entities, status 429
at com.vnera.dataproviders.core.common.impl.dataprovider.utils.HttpUtils.checkCodeAndThrow(HttpUtils.java:54) _[dataproviders-0.001-SNAPSHOT.jar:_]
at com.vnera.dataproviders.core.common.impl.dataprovider.utils.HttpUtils.checkStatusAndThrow(HttpUtils.java:34) _[dataproviders-0.001-SNAPSHOT.jar:_]
at com.vnera.dataproviders.core.common.impl.dataprovider.utils.HttpUtils.checkStatusAndThrow(HttpUtils.java:23) _[dataproviders-0.001-SNAPSHOT.jar:_]
at com.vnera.dataproviders.core.impl.vmware.nsxcommon.AbstractDatasourceFetchUtils.handleErrorResponse(AbstractDatasourceFetchUtils.java:276) _[dataproviders-0.001-SNAPSHOT.jar:_]
at com.vnera.dataproviders.core.impl.vmware.policymanager.utils.PolicyManagerUtils.handleErrorResponse(PolicyManagerUtils.java:1728) _[dataproviders-0.001-SNAPSHOT.jar:_]
at com.vnera.dataproviders.core.impl.vmware.nsxcommon.AbstractDatasourceFetchUtils.fetchData(AbstractDatasourceFetchUtils.java:87) _[dataproviders-0.001-SNAPSHOT.jar:_]
at com.vnera.dataproviders.core.impl.vmware.nsxcommon.AbstractClusterDataSourceFetchUtils.fetchData(AbstractClusterDataSourceFetchUtils.java:49) _[dataproviders-0.001-SNAPSHOT.jar:_]
Aria Operations for Networks 6.12.0
Aria Operations for Networks 6.12.1
Aria Operations for Networks 6.13.0
Aria Operations for Networks 6.14.0
Latency and BDF profile issues:
Issue A: When latency is enabled via Aria Operations for Networks UI, the NSX Latency flag in the vRNI collector database isn't set to true as we are not able to update the Transport Zone with the BFD Profile. This prevents deletion of latency profiles and configurations on NSX Manager when latency is disabled, potentially causing an "already configured" error on subsequent attempts to enable it.
Issue B: During latency disablement (via Aria Operations for Networks GUI, NSX data source disablement/deletion, or migration), vRNI may only delete the BFD Profile and not its path from the TZ due to Issue1 leading to data path issues in NSX upon manager restart. If the BFD profile is still being referenced somewhere (in this case Transport Zone), the deletion of the profile should not be allowed. This a known issue in NSX and has been fixed in NSX 4.2.2
Above mentioned issues are now fixed in Aria Operations for Networks 6.14 Patch8, Build number 1749832225
Aria Operations for Networks patch can be downloaded from Broadcom Support portal port login.
To Download GA patch click here
File name: VMware-AriaOpNetworks.6.14.0.P8.1749832225.patch.bundle
File Size: 969.31 MB
Note: Above patch is cumulative of any previous patches for Aria Operations for Networks 6.14.0
Review below procedure and steps to apply Aria Operation for Networks Patch from GUI:
Note:
When the upload is complete, Aria Operations for Networks GUI show the Bundle Upload Complete message notification within 2-3 minutes and the bundle processing happens in the background.
Until the upload of the package happens, ensure that the session is not closed. If the session ends, you have to restart the upload process.
Do not refresh the page after bundle upload, until you see the Update Available message notification.
