Power on Task for Aria automation on Aria suite lifecycle fails with error code LCMVRAVACONFIG590070
Article ID: 401444
The Power On task for Aria Automation on Aria Suite Lifecycle Manager is failing with the following error:
Error Code: LCMVRAVACONFIG590070
Failed to start vRealize Automation services. Check the vRealize Suite Lifecycle Manager log for more details.
Failed to start services on vRA <vRA-FQDN>. For more information, log in to vRA and check the file /var/log/deploy.log.
Querying the pods shows proxy service pods in CrashLoopBackOff state.
VMware Aria Automation 8.x
vIDM certificate is changed and the new certificate is not trusted on Aria automation
1. Re-trust the Aria automation with Identity Manager
2. Re-deploy the pods by running /opt/scripts/deploy.sh command.
